Front wheels
Started by Nitrowing, 30, July, 2008 - 15:31:04
Nitrowing
ebay number 330257254459 12" front wheels (unfortunately plus a matching rear) for £5 + p&p
ogb
front wheels are mostly 80mm width (fork opening) and rear wheels 100mm
blabblub
Yeah I had to do the same I managed to get my blood pressure up to about 250 PSI
I was seeing stars ( I dont mean George Clooney n Sienna Miller either ) by the time I got the wheel in to position
blabblub
guys, what wheels are you using ?
The last two steel wheel conversions I did was with wheels from Halfords, and they just bolted straight on with no problems whatsoever   :P
Mind you, the last one was metallic pink.... :o, so perhaps not so perfect after all  ;D
blabblub
tried halfords
I left not sure they had ever seen a bike before
I have to say, my local Halfords have been really great. They tend to sell me the steel front wheels from kiddies bike that they have raided for spares.
On a different note, I purchased two of the steel wheels from the ebay seller mentioned earlier and they are okay  ;).
Mole
c5martin
Yes I had to investigate the front wheel! ::)
The seller says that this item is a brand new aluminium front wheel not steel. 8)
That's what made me buy it. ;)
Looks cool too. 8)
Quote from: Karl (C5Alive) on  06, August, 2008  - 21:07:07
..... I purchased two of the steel wheels from the ebay seller mentioned earlier and they are okay  ;).
I fitted one of these "Ebay" wheels to Martin's C5 - and had the same problems you guys experienced. Got round it by removing the locking nuts and using some washers. Works well , but not as trouble free to fit as the Halfords wheel.
Nitrowing
#10
Aluminium always dissipates heat better than steel - that's why it's used as heatsink material.
Nitrowing
It's pretty irrelevant as most of the weight is over the back wheels! I've sourced a cable operated brake caliper and am looking at mounting a disc on the rear axle.
Quote from: Nitrowing on  07, October, 2008  - 23:02:47
You're right about the brakes being quite poor.
Check out filcools conversion ;
http://c5alive.co.uk/forum/index.php?topic=172.0
He's done a superb job on that rear brake
