METAL GEARBOX INSERT
Started by C5 ENTHUSIAST + RESTORER, 29, September, 2011 - 10:43:46
Hi all just had the gearbox inserts finished ..
The body is made aluminum and the tooth  sprocket  is steel (will never wear out ).But it could be removed and a cog fitted in it's place if that is what you wanted ...
I have the same gearbox fitted to my 24 volt c5 and it works OK no problem.
But i do not drive it full on .
so there is no  guarantee on the gearbox or your motor  as it is the way you use it that counts ....
Pyrasanth
Hi Chas,
Are you selling some then ? If so how much buddy
Nice one Chas, just as our conversation you have done it, I have also emailed you.......
#3
I want one as well for my 24volt project  ;D ;D ;D ;D
thedesigntailor
So... are these good for increasing reliability?
Are they worth getting on a 12v?
Are they easy to fit for a dunce like me?
How much?
What's the meaning of life?
  :D
Jonny
i'll take one if there's any left :) does the pulley on there work with the c5 belt and pulley?
Hi there drive pulley on the new gearbox has the same amount of teeth as the original and the belt will fit as normal ..
Regarding fitting..It can be easy but you must know what you are doing with it..
But  it's not for a beginner
I am at the moment I'm making some Gearbox pullers which will make it easy and safer to dismantle the gearbox .
Will post post photos when they are made ....
Hi could you please let me know if you want the gearbox insert then I can get a price for a job lot
bye Chas
Hi Chas - I would be interested in 1 maybe two depending on cost  :) :)
#9
Chas
Put me down for one  8)
Jonny
plumber
hi there chaz can i have one too many thanks the plumber
Hi there I do not have your email address to contact you ....Chas
Jim
Wow, I had been wondering about getting one of those made, nice work. Am very interested but depends on price? Jim :)
becks
#14
how much are these i wonder?
