Fuses for the C5, should they slow blow or normal?
Started by joggaeco, 21, October, 2011 - 01:36:06
joggaeco
Hi! All,
I was in a quandry about this, so I replaced them with normal fuses to be on the same side.  For an  ebike I had, the fuses had to be slow blow.
Whats the case for the C5?
Many thanks,
Joggaeco
I don't think the original fuses were slow blow - the amount of circuit board damage i have seen i think your choice of 'normal' fuses is the correct one ! :)
joggaeco
Thanks! I bought those, just in case!
That's put my mind at ease.
Just a tip, I always carry some with me, shame to spoil a run, juts becuse of a fuse.
If a fuse blows there is normaly a reason that will need attention  8)
Hi, I agree with POD11 you have an issue somewhere. Good luck with the fixing.
