Column for the front panel
Started by Thor069, 03, April, 2012 - 11:01:48
Thor069
Hello,
So I have a column to make the front/noise of the C5fix and that he doesn't wobble so much.
It's self made from Wood and I will use this to fix on it a control panel.
But first I will look to put a gear in the chain while the pedaling is too bad, high rhythm for me.
Best regards.
Thorsten
frankev
Hi Thor,
I wonder, won't this wooden post create more noise then it reduces? The trembling of the body is transmitted to the chainspace witch could work as a resonance case. Don't know. Let us know how it works out for you.
greetz
Frank
Hi there just a question are the black plastic washers in place of that hold the  pod in place .....bye Chas
frankev
Quote from: C5 ENTHUSIAST + RESTORER on  17, April, 2012  - 14:10:45
Hi Chas, I try to figure this one out, aren't the black plastic washers that hold the pod in place, white?
bye Frank
#4
Hi there Frank ..The washers are black They fit between the pod and the white plugs underneath the front ...Take a look on my site on the forum (The Chas section) And look at items that are for sale ... Bye Chas
