POD failure part x
Started by Ton C5, 02, February, 2013 - 15:57:53
Ton C5
One of my C5 has a pod with a fried resistor R21
i am unable to find a layout or plan of the pod.
is it worth a try ? the rest looks okay
You will find it is a common fault on the pod ...It will need replacing ...
Chas
Ton C5
Yes but with what ?
and will it be enough to replace only the resitor or is it wise to replace more ?
#3
What I would do is to replace the burnt out resistor then Clean all the contacts then check the pod  out ...R21 is a 10R resistor
Chas
Ton C5
Okay 10 R ?  uhhh, i might not be the sharpest knife in the block but do you mean 10 K ohm or just 10 ohm  ???
btw i jus got the engine working  :) cleaned en greased and that did the job
