Horn
Started by Umpa, 14, June, 2009 - 20:05:05
Hi Gang,
I have fitted two horn kits (from Adam Harper) and followed the instructions and can say they work a treat.
On 'Huey' my original C5 with a wiring kit fitted when I switch it off the horn won't sound if the button is pressed.
On  'Dewey' my - well our Marks C5; with original battery loom, the horn works when switched off with the battery block still connected.
Is this normal ? seems as tho part of the C5 is still live even tho its switched off? - also the pod remembers its battery state so you cant switch off to reset the pod if the battery runs low.
It's not a problem but I wonder if its normal or do I have a fault ?
thanks
Ian
Hi, just a quick upate.
After speaking to Adam I can tell you that the above is normal.
