New items coming to the store
Started by Karl, 27, April, 2008 - 21:28:38
Following the joining of C5martin & C5alive the following items will shortly be available ;
Replica mudflaps
Motor mount bracket to stop drive belt slippage
Improved wiring kits
Replacement chain tensioner brackets to replace the clips and kits to prevent the chain bouncing off.
Replica boot clips.
Just a few examples to keep you updated about all the background work going on  8)
The website will be updated soon.
c5martin
Tri Colour Fans have arrived for new kits.
Karl should be delivering the metal this week end so it's looking good
for end of next week to have them back on sale.
c5martin
Replacement Hubs under development.
Prototypes are installed and working well.
Could supply different colours for C5's from the dark side.
O/K the coloured ones are for Karl.
Should be in the shop in October.
There is just not enough time.
The New 24v kit is also taking shape. ;D
c5martin
Second Battery Wiring Kit.
This kit is an ad on to the existing power wiring kit.
The new kit will give you the ability to run two battery and thus increase the range of your C5.
All the usuall reverse battery protecting etc that you expect from C5ALIVE is included.
The first prototype will be on test at the Brooklands Meeting.
If you have already fitted a power wiring system this kit fully compatible with the C5martin version.
This new kit should be available October/November 2008. ;D
