Author Topic: Brand New (Some Original)Some used Sinclair C5 Spare Parts for Sale....Now!!  (Read 75940 times)
**Sinclair C5 Spare Parts and Price Guide**
1. Working Brand New and UNUSED C5 Motor +Gearbox  £140.00; P&P: £13.00 ( UK ONLY)
2. Large Thin Gearbox Bearing: £4.50 +2.50 p&p
3. Large Rear Axle Bearing: £2.50, P&P: £1.00
5. Roller Bearing that fits inside of Motor Mount (axle point):SORRY ALL SOLD
6. Steering Location Cone Nut (Fits both front and center steering points): £1.50, P&P: £1.00
7. Light Switch : £0.70, each + P&P: £0.60
8. Bearing for the motor will fit both ends. sorry all sold
9. Bearings for the front of the motor (small one's )  £8.00 A SET (2) + £1.00 POSTING
10. Pod washers black plastic brand new had them made £1.70, for 2 + p&p: £0.60
11. One pare of brake shoes £12.00 + p&p: £2.00  (all sold sorry)
12. Battery covery top small £3.00 + p&p: £1.00
14. Back Brake puller bracket (sorry all sold)
15. Back Brake spindle bolt £1.30 + p&p £1.00  SORRY ALL SOLD
16. Top half of the brake plastic fitting (sorry all sold)
17. Set of spanners (2) (sorry all sold)
18. Motor support bracket (sorry all sold)
19. Boot clips £2.00 each + p&p 0.60p
20. Back axle O rings (sorry all sold)
21. Body rubber supports bungs (a set 2 )  £2.00 + p&p  £1.00  (sorry all sold)
21. Battery support bracket (sorry all sold)
22. Control box cable seperater (sorry all sold)
23. Brake cable clips £0.30 + p&p £1.00 Sorry all sold
24. Bearing  cup for steering no bearings left £1.50 + p&p £1.00  (sorry all sold)
25. Steering lock washers £0.50 + p&p  £1.00  (sorry all sold)
26. Steering nut £1.40 + p&p £1.00  (sorry all sold)
27. Rear brake bracket (sorry all sold)
28. Peddle crank and bearing £3.99 + p&p  £2.00  SORRY ALL SOLD
29. Back brake metal insert (sorry all sold)
30. Second battery key switch holder (sorry all sold)
31. Handle bar grips £4.00 a pair + p&p  £1.00 ALL SOLD
32. Key switch 2nd battery (can be made to work on the main side) £21.00 + p&p £5.00  Sorry all sold
33. Left pedal with arm  £4.99 + p&p £2.50 ALL SOLD
34 . left and right pedals no arm £2.00 each + p&p £1.50 each ALL SOLD
35. Right pedal with arm £4.99 + p&p £3.50 SORRY SOLD    little surface rust on it but ok ..
36. High Viz mast stickers £2.99 a set + p&p £0.70 (0 left)  SORRY ALL SOLD
37. Steering ball joint £5.00 (Male & female) + p/p £1.00 (3 left)
38. Body fixing washers (4) £1.70+ P/P £0.60 (10 SETS LEFT)
39. Frame plugs (for securing the control box to the frame (2) £1.80 + p/p £0.60
40. Large Steering bearings(2) will fit front/middle steering points (you will need 2 bearings for each)SORRY ALL SOLD
41. Mud flaps (2) ready to fit just needs 2 holes drilling .£10.99 + p/p £3.50....
42. Headset for the steering includes 2 bearings you will need two sets 1 set is £7.00 + p/p £2.00
43. Hazard Warning Flasher kit £9.50 + £2.00 p/p
44. C5 Mud Flaps Stickers  £1.30 .PER SET + £0.60 P/P
45. C5 Battery support Straps  £8.50 EACH + £2.00 p/p
46.C5 Boot inserts £12.50 + each + £2.00 p/p
47. C5 Chain Tensioners £19.00 each + £2.50 p/p (the new ones that I have made)
48 . KEY SWITCH WITH KEY £25.50 each + £3.00 p/p (Used)
49 . KEY SWITCH WITH KEY AND BOOT LOCK  £35.50 each + £4.00 p/p (Used)
50   NEW FRONT BRAKE CALIPERS BLACK/WHITE/CHROME . ALL SOLD
METAL GEARBOX INSERTS MADE TO ORDER £75.00 + POSTING £4.00
52 . 1/2 LINK CHAIN £2.70 EACH +£0.60 POSTAGE
53   Hi VIZ RUBBERS £6.00 PER SET (2) FREE POSTING  ( SOLD)
54   POD HOLDERS REMADE  £6.00 PER SET (2) FREE POSTING  (SOLD)
55  Back wheel bearings £3.50 a set (2) + £1.00 p/p)
56. Different coloured stickers
56 Large drive cog roler bearing £5.00 + £1.50 + P/P
Most parts are ORIGINAL BRAND NEW Old stock
C5 Motors will be despatched via courier, other items via Royal Mail, First Class post
C5 Motors are later type with white gearbox and extended drive cog teeth
For mulitiple orders postage costs may be reduced but will be agreed upon
Payment terms: Paypal / Cheque Postal Order/ Cash on Collection
For all orders, please contact me through the C5 Alive web site (Personal Messages Only)
Photographs of all items listed above for sale to follow, any questions......Just Ask!!!
(Thanks to Karl and C5 Alive for allowing me to post this message)
Regards and Happy C5ing
Chas  ;;   Please contact me if you want to buy anything before paying  .
 [/color]
« Last Edit: 25, July, 2014 - 08:04:51 by C5 ENTHUSIAST + RESTORER »
Re: Brand New (Original) Sinclair C5 Spare Parts for Sale....Now!!
« Reply #1 on: 22, April, 2010 - 20:01:41 »
HERE ARE THE PHOTO'S OF THE ITEMS THAT I HAVE FOR SALE
PLEASE CHECK ABOVE TO SEE IF NOT ALREADY SOLD THANKS  CHAS
ALL ITEMS BELOW ARE NEW OLD STOCK BUT ARE LIMITED
« Last Edit: 01, May, 2012 - 12:31:58 by C5 ENTHUSIAST + RESTORER »
BATTERY STRAP/Clip
« Reply #2 on: 27, April, 2010 - 19:42:57 »
1
« Last Edit: 19, June, 2011 - 10:40:55 by C5 ENTHUSIAST + RESTORER »
« Reply #3 on: 02, May, 2010 - 18:46:28 »
price list
Here are the Battery straps that I have made and will fit the largest battery that you can get in the C5
« Last Edit: 19, June, 2011 - 10:45:42 by C5 ENTHUSIAST + RESTORER »
« Reply #4 on: 03, May, 2010 - 10:54:37 »
I hope I have sent you an e-mail correctly Chas, I'm after a set of rear brake shoes please, thanks.
« Reply #5 on: 11, May, 2010 - 19:40:51 »
Hi Chas any luck with the two boot locks yet ?
Radiomarty
« Reply #6 on: 12, May, 2010 - 07:28:37 »
Are any of the gear boxs for sale ???
I am after a complete one.
« Reply #7 on: 12, May, 2010 - 20:50:57 »
Radiomarty
Hi Marty, ther is a boot lock and key on e-bay
« Reply #8 on: 12, May, 2010 - 20:51:54 »
Hi Chas, received the rear brake shoes yesterday, many thanks again.
Offline ljalberga
« Reply #9 on: 21, May, 2010 - 10:25:52 »
Chas, can you post a piccie of the key switch for the second battery please !
I need one for my main battery and wonder if it is customizable...!!!
marcdonnelly
« Reply #10 on: 04, June, 2010 - 10:49:11 »
Hi chas i would like to order a set of bearing,s for the front of the motor can i send you a cheque for the £3.50 thanks marc.
« Reply #11 on: 04, June, 2010 - 18:19:12 »
Hi there Marc ..yes no problem
marcdonnelly
« Reply #12 on: 04, June, 2010 - 19:19:34 »
Thanks chas can you send me the address and your surname i and i will post the cheque asap to you
chriswish
« Reply #13 on: 20, October, 2010 - 09:26:37 »
 :)Hi Chaz,
Good to hear from you again, can i order the following please,
1 pair handlebar grips if you have any.
2 sets of all the wheel bearings.
1 set of headset bearings if you have any.
Let me know what i owe you
Thanks a million
Chris Wish
Address edited out for security reasons.
« Last Edit: 09, November, 2010 - 18:41:53 by Umpa »
« Reply #14 on: 20, October, 2010 - 19:45:37 »
Hi there Chris no problem will email you ..Bye Chas
