Drive cog and axle assy.
Started by marra, 20, August, 2010 - 16:57:56
marra
Well Marra made a major headache for himself ... ME  :( Completley striped down the c5 ( both ) sandblasted and powder coated frames. During the strip down i did document the parts with pics, but the drawings and clips have been thrown away by mistake. I am now left with the whole thing in bits  :-[
  So at the moment I am reassembling the axle and have come to a problem. Can someone provide a drawing or a description of the washers and O ring assy that holds with the motor mount and drive cog.  :P I cannot se anything in the download sec. between the motor mount and drive cog i can remember removing washers.... I think.
Oh, also had quite a few other bits and washers that came with the c5 so I cannot know what i had before the strip down.... limbo.... please help.
The Marra.
marra
thanks for that. had a look and gave me an idea. From what i can work out on the motor side. There is a large washer , then a rubber O ring and the motor mount. Then a larger washer and drive cog then another larger washer and the teethed tube holding those ? drive belt then wheel ? Does this sound right or am i missing something.
