Maintenance guide
Started by thedesigntailor, 07, September, 2011 - 19:55:19
thedesigntailor
Would any of the C5 wizards be able to put together a brief maintenance guide for dimwits like me?
I've heard talk of keeping the gearbox greased but wouldn't want to go about spraying WD40 willy nilly.
Thanks  :D
Dan
Yours has recently been rebuilt so the gearbox and motor should be fine for a while yet. Greasing the gearbox is a dismantling job that cannot be done with the motor/gearbox unit in situ ;
Motor assembly
Gearbox removal
http://c5alive.co.uk/forum/index.php?topic=1217.0
Pedal crank, steering and front fork bearings were also recently re-greased on yours so should also be fine for quite a while yet , again dismantling is the only way to access them;
http://c5alive.co.uk/forum/index.php?topic=239.0
Front wheel bearings are standard bicycle components so no worries there, rear axle bearings are another matter ;
I'd expect the first areas to show wear and tear will be the usual consumables such as tyres, tubes, brake blocks/shoes ,brake cables, chain ,drive belt and chain tensioner clip. The rate of wear will depend on usage  ;)
Short answer is - keep the chain oiled nicely  ;D
thedesigntailor
Thanks Karl
Pretty maintenance free considering  :)
